Consulta XENON
Publicado por vicpower, Enero 13, 2009, 21:54:45 PM
vicpower
Estoy por comprar los XENON para el Clio, mi consulta era, de cuantos Watts tiene que ser?
Estoy por comprar un Kit que tiene esta descripcion:
2 x H1 100 Watt Fog light bulbs
2 x H7 100 Watt Main (high) beam bulbs
2 X HB3 100 Watt Dipped (driving) beam bulbs
and a pair of ICE White sidelight bulbs
Saludos!!
Ese kit incluye 3 kits de xenon + posicion? o es un kit de  8 lamparas simil xenon?
y poné precio asi te puedo ayudar más.
vicpower
Cita de: cliodemi en Enero 13, 2009, 22:04:02 PM
Me las compro por Ebay...Me salen $60 mangos...Te paso la descripcion (esta en ingles)
XENON GAS ICE WHITE (5000K) 100 Watt HEADLIGHT KIT INCLUDES:
This light is powerful and intense with a distinctive tint to give your car that modern HID look without any of the cost.
Xenons ICE White 100 Watt delivers up to 100% more light than a standard bulb: the ultimate vehicle lighting upgrade that can be fitted simply and quickly.
The extra quality and quantity of light provided by Xenons ICE White make them ideal for drivers who want their cars to stand out in a crowd, while ensuring driver and passenger safety is of the highest priority.
The xenon gas charged bulb allows the filament to burn brighter coupled with a blue filter produces a much whiter light than the normal 'orange' you see in ordinary bulbs Drivers find this of great benefit on long journeys helping with the concentration and effort needed during night time driving.
Here are some of the benefits you'll see:
Up to 100% more light on the road
Better reflections from road signs
UV resistant Cut Quartz allows safe usage with plastic lenses
Optimised colour temperature to give ICE white light
Direct replacement with existing lamps
100W BULBS ARE NOT APPROVED FOR ROAD USE
Viene con 6 meses de garantia...
te dejo la foto
http://www.subirimagenes.com/otros-100wh7hb3h1501-1799488.html'><img src='http://s1.subirimagenes.com/otros/previo/thump_1799488100wh7hb3h1501.jpg
cristobel
No es Xenon, es simil... como las lamparas Wega HID
vicpower
Cita de: cristobel en Enero 13, 2009, 23:42:40 PM
Seee, seran buenas??
lwtopo
Che, ninguna de esas son Xenon de verdad. No deben ser mas que las chinas que venden en todos lados aca y que dicen xenon. Por lo general las lamparas de xenon consumen menos (35 watts) que las originales (65 watts).
Megane I Fase II
martio
Cita de: lwtopo en Enero 14, 2009, 00:13:11 AM
eso mismo estaba por decir que las xenon no consumen 100W sino que consumen 35Watts
55w las originales 35w las de Xenon. Hay de 55w xenon tambien
Si te interesa un kit de Xenon hablame por mp. A eso me dedico, si tenes alguna duda o consulta tambien te oriento asi no te cagan si compras en otro lado.
Ck_soluciones
Los Xenon de 55Watt no son mas fuertas , unicamente tardan mas en encenderse , no los recomiendo
Si quieres una luz bien blanca y potente tenes que elegir el valor termico mas bajo , por ejemplo  4300k ( Laguna2 desde la fabrica ). Con un equipo de 35Watt y 6000K logras una muy buena iluminacion todavia
simplemente_juan23
Cita de: cliodemi en Enero 14, 2009, 03:41:36 AM
Como andas? ClioDemi tenes idea cuanto sale un Kit de Xenon para mi Clio ( Clio 2 RT modelo 2000 ), digamos no el mejor pero tampoco el peor ... algo medio pelo, para tener una idea ...
Muchas Gracias
cristobel
Cita de: simplemente_juan23 en Enero 14, 2009, 09:00:39 AM
Muchas Gracias
Medio pelo no... mi amigo te vende el mejor!!
GaStöN
...amigo no pongas esas lamparas!!!, me parece que los cables, la compu o las opticas no se van a aguantar un consumo de 100 watts (es como un 50 % mayor al original).
Gabriel C
Cita de: cristobel en Enero 14, 2009, 09:07:31 AM
Muchas Gracias
Na na na na na... se ve que demi esta repartiendo comisiones por alli !!!
Son mis buenas referencias!!!!
Colono
Una pregunta muchachos...
Estoy queriendo poner xenon en la bestia, pero me dicen que si quiero hacer señas de luces con las altas no voy a poder. Que no tienen reacción rápida o no se que.
Verdad o verdura?
"26/03/2007 -- 30/06/2010" Ã,¡Ã,¡Gracias por 3 maravillosos años!!
